Thread: How do you fertilize grass around your inground pool?
    Jul 2011
    Boca Raton, FL
    Default How do you fertilize grass around your inground pool?
    We got our new inground pool this summer. The sod around the pool is green but it's gotten a few dollar weeds that have invaded the sod (St. Augustine - Palmetto variety). I'd like to add some fertilizer and weed killer to the backyard sod, but I'm concerned that the ingredients in, say, Scott's Bonus S weed & feed -- they'll cause metal staining if any of those pellets fall into the pool water. (I don't know if there's a risk of staining, but I'm guessing there might be).
    How do you safely fertilize the sod around your inground pool? Is it true there is a risk of metal staining by broadcasting fertilizer on the grass that surrounds your inground pool?
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Scottsdale, Arizona
    Default Re: How do you fertilize grass around your inground pool?
    Use a spreader and keep your back to the pool .
    And yes, the iron in the fertilizer will leave rust stains on your plaster. Vitamin C tablets will remove them though so don't panic if it happens .... ask me how I know
    usa a drop spreader in the 1st 20 or so feet around you pool
