Results 1 to 10 of 10
Thread: Leakage
    May 2010
    Default Re: Leakage
    I'll do the leak test, then cross my fingers! Thanks.
    May 2010
    Default Re: Leakage
    Any luck? I appear to be losing about a 1/4 inch a day, never had it go down even close to this quickly. I will also try the test, but won't be able to let it sit long enough until Tuesday... long time for an impatient guy like me to wait!!
    Thumbs up Re: Leakage
    Quote Originally Posted by terpsucka View Post
    Welcome to the forum!
    There's a nice little phrase here called POP (Pool Owner Patience) - you seem to need some
    Pool water issues usually take a while to become evident, if it took a month to get to the problem stage, it's gonna take more than a day to fix it! As Ben espoused in the Pool Solutions site, there is NO magic chemical you can add to the pool to immediately correct a problem
    What it boils down to is - follow the advice here, have patience and then you'll have a pool that will no longer give you problems - as Carl says "2 - 5 minutes a day" (spent on maintaining the chems) will keep your pool sparkling and hassle free
    The POP also is required for the open bucket test (though I'd prefer to see a 'vessel' test first - the vessel test is where you plug all the lines to and from the pool, mark the waterline and see if the water drops more in the pool than in the bucket, this helps to identify if the pool shell/ liner is leaking or if it's in the plumbing) If the vessel test is OK, you know to look into the plumbing for the leak - I'll tell you how to 'homebrew' a pressure tester for the lines {actually I think Al has already posted his method}
    I'm more than willing to spend some time and help the posters here find the source of their missing water! It's just easier if y'all do your homework and do the prescribed tests first Heck, for the low, low cost of $0, I'll give you my best advice on how to fix the leak, once it's identified
    May 2010
    Default Re: Leakage
    Quote Originally Posted by waste View Post
    Ha ha.... you're right about that. Patience is something I have very little of!! Thanks for the vessel test idea also.... I will try that one after I try the straight bucket test, assuming it comes back positive for leakage. I'm actually thinking maybe the "leakage" is just the result of my kids getting bigger and splashing out more than they have in past years, especially since they've been in it way more this year with the hot weather.
    May 2010
    Default Re: Leakage
    Lucky me, mine is from evaporation! Thanks for telling about the bucket test.
    Who says there are no easy answers?
    Honesdale PA
    Default Re: Leakage
    Post #17 in this thread
    http://www.poolforum.com/pf2/showthread.php?t=261
    should have links to a couple pics for a pressure test jig and a description.
    If the pics aren't visible for some reason let us know and we'll figure something out.
    On a patience note, for a couple spring seasons I've chased my tail thinking I have a leak and it indeed was evaporation. Simply caused by warmer water, cool dry nights, and wind. You'll be surprised how much water can be lost.
