Results 1 to 10 of 17
Thread: First Pool water trouble
    Default Re: First Pool water trouble
    Hmm..I'm not the metals expert on the forum, but I can tell you what I know....
    1. There isn't a particular metal sequestrant that we recommend. Mbar (one of the forum's resident metals experts), says that she has used a variety of them, and that they all work equally as well. Check and see which one is cheaper, because I understand that they can get pricey. You can read through the forum for posts by her, she addresses that question in other posts too.
    2. If draining and refilling is a viable option for you, then it is going to be much easier for you to not have to fight the metals in the water for the life of your pool if you can remove at least some of them before they get into the pool. Keeping water balanced is somewhat of a chemical tightrope when metals are involved in the water, and it'll be much easier on you in the long run if you don't have to deal with it. It is also going to require regular additions of metal sequestrant throughout the life of the pool. So....if you can drain/refill without too much of a problem, and filter out at least some of the iron, then I would do so.
    3. I'm fairly confident that you'll be aware of the presence of metals by the water quality--when the pH or chlorine get too high and there's not enough sequestrant in the water, it will start to turn brown/orange like it is now. So...there are metals tests out there, but honestly I think once you get this initial startup under control, you won't need one at home. I don't know how much they cost vs. how close you are to a pool store that CAN test for metals, but I would think you'll be ok without buying a special test for it.
    We do recommend buying your own test kit that will test for the other water parameters, though--chlorine, pH, alk, stabilizer, calcium (not needed in your pool but nice to know the baseline level). Not only will your results be more accurate than the pool store's (fresh samples, consistent testing methods, etc) but it also doesn't give them the opportunity to try to talk you into buying hundreds of dollars worth of stuff that you don't need. (We'll start with calcium, move onto phosphate remover, and on to .....) The test kit we recommend here is the Taylor K-2006, which can be bought online at http://www.amatoind.com, http://www.spspools-spas.com, or http://www.amazon.com/gp/product/B00...SIN=B0002IXIIG . It's a little more expensive at the Amazon site, but PF gets a donation from them if you get it from that link. I know that the test kits can be a little pricey, but I guarantee you that it will pay for itself tenfold over just this summer alone, and is going to be necessary to give you full control over your pool, especially if you're going to be dealing with a metals issue.
    Upper Midwest
    Thanks for the info Janet. Draining and refilling is a possibility I only have a 3200 gallon pool. I will have to drain and refill yearly anyway. It gets cold enough here that keeping it year round would probably not be a good idea. My only question with the prefilter is if would remove clear iron. I've read that a filter can only remove iron once its oxidized. Its possible for the filter to do that, but I'll just have to investigate a little more.
    It sounds as if it would be less hassle if I can remove as much as possible beforehand and probably less expensive as well in buying and maintaining the pool with the right chemicals. In the end I could run it through our house water which is conditioned, it just takes forever. I did'nt realize using the raw water would be so problematic.
    Is the Taylor K-2006 that much more accurate of a test kit than the similar one I got from Walmart? They seem to test the same things (its a 6 way kit probably hth).
    If I decide to use the sequestrant on my water as is, should I use a conditioner/stabilizer to help maintain chlorine? I know you said the sequestrant would probably affect chlorine, I didn't know if stabilizer would help.
    What about floccing? I've heard some do this to remove stuff from the water. It sounds good (the idea of removing iron or whatever), but are there drawbacks or reasons its not recommended here.
    Thanks again for the information. At least this problem is becoming something that seems a little more manageable as opposed to something that bordered on impossible.
    Kris
    sturev's Avatar
    sturev is offline Registered+ Thread Analyst sturev 0
    May 2010
    Kris, I have about the same size pool and I filled from the treated house water and it saved me a ton of money/time/hassle!!! I'm on a well also, with high iron and lots of other 'fun' stuff (sulfur, etc, etc). It only took about 9 hrs to fill with a garden hose, so if it's possible for you, I would HIGHLY recommend it (as long as your house/treated water is indeed better).
    I never checked into the prefilter, but from what I've read here, no one has named one that really works (that you can buy). There have been a few 'homemade' filters, but not sure it's worth it in your case (you have a smaller pool and filtered water already).
    Yes, the Taylor K-2006 is more accurate for testing high shock levels and overall just a better tool to enable you to take control of your pool!!! There are several differences in the testing and the Taylor is really, really worth it!
    If I were you I would forget about the sequestrates & other 'things', and just refill... But, that's just my opinion... I'm of the mindset that less is more when it comes to putting stuff in my water!!!
    Evan S.
    AG FastLane Pool, 9x13 ~ 3,000 gal, COVERED/INSULATED 23X7, 30 gpm water pump (runs 12 hrs a day) AND a Hayward Power-Flo LX 1.5 hp Pump (only used on occasion for the pool sweep), Hayward 100K BTU Heater, Waterway Flo-Pro Skim Filter & Slime Bag, no other filters
    Hi Kris,
    As far as the filter removing "clear iron", I don't know the answer to that one--but I will certainly ask Ben (the owner of this forum) to take a look at this thread and I'm sure he can help you out there.
    As far as the Taylor test kit, it's a more complete one than the one you got from WalMart. All of the tests with the exception of Chlorine work the same way. However, the chlorine testing is much different...with the WalMart kit, you add 5 drops of reagent to pool sample to achieve a yellow color that you match to a scale reading up to 5 ppm. Many people have a problem with accurately reading the color comparator, and many people need to maintain higher chlorine levels than 5 ppm--in fact, everybody that is shocking the pool needs higher levels than that! It also only measures total chlorine, which is actually a combination between Free chlorine (the amount of chlorine in your pool available to fight stuff in the water) and Combined chlorine (the amount of chlorine that is currently tied up with fighting stuff in your water). Being able to distinguish combined chlorine (CC) is at times very helpful, and at other times a requirement. The Taylor kit works by adding a scoop of powder to the pool sample, making it turn pink. You add drops of reagent until sample is clear, multiplying count x 0.5 to get free chlorine level, then add 5 drops of a second reagent. If it doesn't change color, you know you have 0 CC. If it changes to pink, you add the first reagent drop by drop until it goes clear again, and multiply by 0.5 to get the CC. Going from pink to clear is easier to accurately gauge than comparing shades of yellow for many people, being able to measure CC is important for many situations, but the ultimate advantage in this method is that it gives you accurate testing of chlorine up to 50 ppm.
    Regarding stabilizer, yes, you will need to add stabilizer to the water to help protect your chlorine from the sun. We recommend that people target 30-40 ppm, then add about 1/2 the product required, because it's much easier to add more later to increase it than to overshoot it and have to drain/refill,especially after they've gotten a water problem resolved! If you have a skimmer, you can put it in through there where it will go to the filter and sit until dissolved, which can take up to 4-5 days. You can't backwash/clean your filter in that time, though, without washing it out, so another method is to put it in an old tube sock and suspend it in front of a return until it dissolves. No need to test for it for about a week, though, because it takes a long time to dissolve and show up in tests.
    I would leave the flocculants alone in your case, because I don't think they'll help. Flocculants are used to make small particles stick together to make bigger particules that the filter can catch or that will sink to the bottom to be vacuumed up. In the case of iron in solution in the water, I don't think this is going to be applicable to you, but again, I'll ask Ben to take a look and offer whatever suggestions he can.
    Hope this helps!
    I'm really having a hard time with your question, because I'm not really equipped to give a "here's how you solve your problem" answer. The whole issue of how to get metals out of Intex pools is a stumper -- they are low cost pools, and have really low capacity filter system.
    Working out a 'best way' is inevitably going to require 'field testing', AKA trial and error. Ideally, I could spend the next 3 weeks shuttling by private plane between the well-water filled Intex pools having this problem . . . trying different combination till I found something reasonably easy and reasonably priced. Unfortunately, being "independently broke", that's not gonna happen. So, the "trials" and the "errors" will have to be yours, not mine.
    Next best thing, I'll tell you what I would try first, if I was you.
    1. Drain your pool, and rinse out the goo.
    2. Refill adding about the label dose of a liquid metal control product. Do NOT overdose. Do NOT repeat the dose.
    3. Add 2x the label dose of polyquat AND keep adding every 2 days.
    4. Adjust your pH to 7.0 - 7.4 using muriatic acid as needed.
    5. Do NOT add any baking soda (alkalinity increaser) or calcium.
    6. Add small doses of borax (1/4 box daily) till you've added 3 boxes
    7. Continue using muriatic acid to keep the pH below 7.4
    8. Add SMALL (1 ppm) doses of PRE-DISSOLVED dichlor to your pool nightly.
    9. Operate your filter 24/7. (Get some extra cartridges before you refill).
    10. Try to avoid having to add lots of water at once.
    11. After the initial dose, only add liquid control product as needed with NEW water additions.
    12. Continue with the polyquat and low dose chlorination, till your filter stops turning really brown.
    13. Switch back to the polyquat and low dose chlorination, any time you have to add more than 1/10 of your pool volume.
    14. Run your filter 24/7 for several days after each water addition.
    Ok. That's what I'd try.
    I'm next going to start writing an "Iron and Intex" FAQ in which I'll try to explain why that's what I'd try.
    Of course, if you have an iron removal system on your household water, filling with THAT water would be far and away the easiest thing.
    But, I wouldn't try to clean up the water you've got, unless you're first get a new and larger filter and pump for your pool.
    There is one exception. If you turn your pump and filter off overnight, and find that the iron has settled to the bottom, leaving clear water on top, you've got a third option. You can VERY carefully set up your vacuum system --- without disturbing the iron on the bottom --- to vacuum to waste, by siphoning onto the ground. Then you can vacuum most of the iron out. If you go this route, you'll want to fill the pool to flooding first, so you have some water to spare.
    Best wishes,
    PoolDoc
    Upper Midwest
    Thanks everyone for your input. It helps put some perspective on my options.
    Thanks as well PoolDoc for your best guess as to what I should trial and error. Jet setting to my place is definitely not what I'd expect. It is interesting the number of similar questions you must field. I just wanted to know what I could I try or what someone would recommend who had more experience with pools than I do. I'm good with trial and error. You've more than given me some options. Sincerest thanks. I'll look forward to your faq to figure out all the whys. Understanding that might help as I'm trial and erroring through it all.
    Although it would definitely seem filling with conditioned water, no matter how much slower it may be, will definitely be less time consuming than dealing with iron in the water.
    Regarding the upgrade of the filter and pump. If I were to consider such a thing, is it worth it for the kind of pool I have and what might you recommend? Just a best guess/opinion. I wouldn't have a clue without somebody giving me one as far as what to get. Thanks for any input you have.
    Thanks again,
    Kris
    mbar's Avatar
    Ashland, PA
    Kris, can you please post all of your results so we can learn from your experiences too? It is how we all learn and we can pass on what works! Thanks
    Northeast PA
    The EasySet is the donut, right? Since you must take down the pool every year, it's probably just easier to fill with the iron-free water. Intex filters will handle ordinary conditions, but serious deviations go beyond what they can do. It's your decision but even a decent small pump and filter will probably cost more than the pool itself. Is it worth it? That is your decision.
    Been there, done that--I had a 15' donut we used for 3 years.
