Closed Thread
Thread: pump wiring
    May 2010
    Default pump wiring
    I installed a hayward 1hp pump on a 15 amp breaker running 110 and it work fine. I was talking to a friend and was told that it should be running 220 on 14/2 wire. Yesterday I installed a new double pole breaker and a double pole switch than I switch the jumper in the pump back to 220 and nothing happens. check all the connections and everything seemed good. So after playing with it and getting nowhere I moved the jumper back to 110 and told the white off of the breaker and back to the bus bar and it works again any ideas?
    Default Re: pump wiring
    1st:
    Are you sure it's a dual-voltage pump? Which model is it?
Closed Thread
  1. Pump timer wiring
    By jqgreen in forum Pool Equipment & Operations
    Last Post: 05-29-2011, 07:23 PM
  2. Help needed wiring 2 speed pump
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2007, 07:59 PM
  3. Super Pump II Wiring Question
    By JWB in forum Pool Equipment & Operations
    Last Post: 04-01-2007, 10:41 AM
  4. Wiring of a 2-speed pump
    By mmcguire in forum Pool Equipment & Operations
    Last Post: 01-15-2007, 01:08 PM
  5. wiring for a heat pump(new IG pool)question
    By freddyttt in forum Pool Equipment & Operations
    Last Post: 09-08-2006, 01:01 PM
