Tricia from South MS
Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
Okay, we just did CarlD's chlorine test on our bleach, and it only came to 3.5% bleach. Maybe our bleach is old and that is part of the problem???
http://www.poolforum.com/pf2/showthread.php?t=10167 (CarlD's chlorine test)
How do we make sure we're buying fresh bleach?
When you say "he added enough bleach to get up to x amount"....are you testing it at that level, or just assuming it's there because that's what the bleach calc says? If you're testing it at the higher level and then testing it at the lower level, then you still have a problem with your water. If you're just assuming that it's hitting the high level you think it is, then you probably don't have nearly the chlorine demand that it appears. With the weaker concentration, it's not going as high as you think, and it's probably not going high enough to maintain a shock level for very long. When you make your next addition, give it an hour or so after the addition to circulate, and then test it to see what you get. That result will make the results from the next test meaningful....make sense?
AS far as buying fresh bleach--there's really no way to know--you could ask the manager of the place where you are buying it how long that particular lot has sat around, but even he can't control things like how long it sat in the warehouse, what the temps were, the storage conditions, etc. I buy mine at WalMart, where there's a HUGE turnover--they completely turn over their bleach (generic, anyway) shelves at least every couple of days.
We haven't done much testing afterward, but will start doing that now. I did buy 4 large containers of bleach from Walmart today, thinking they probably move a lot more bleach. (Our last bottles were bought from 2 different Dollar General stores.)
I also bought some polyquat 60%. CarlD, if you are still reading this, how much would you recommend for algae prevention and a week away? Our pool is about 5000 gallons.
It will be interesting to see what your actual overnight chlorine loss is--measure tonight and in the morning, and be sure and let us know...
Okay, numbers for the evening...
Last FC reported on this post was 11 ppm at 11:30 this morning (Thursday). We did not add any chlorine at this point.
At 4 p.m. today DH added 4 quarts of the Dollar General Bleach (tested to only be 3.5%).
Unfortunately we do not know how much the chlorine had dropped before the bleach was added at 4 p.m. since I wasn't home (stuck in line at Walmart with the whole store full of registers with computers down) and DH did not test at this time.
At 8 p.m. our FC level was 9.5 ppm. We added 2 quarts of the new bleach (Walmart brand), which should have brought our FC level to 15.5 ppm.
At 10 p.m. our FC level was 13 ppm. Either the bleach wasn't 6% or something is eating up the bleach.
We will test in the morning and I will post the results. Then I will probably add a maintenance dose of polyquat 60 to the pool.
Oh, I forgot to submit this reply when I wrote it about half an hour ago. Since then, we have done the test and verified that our Walmart bleach we just bought today is indeed 6 percent. However, we think the Dollar General bleach may have gotten a bad rap due to measuring mistakes. We used a pipette we had from a microscope set to measure the 1 mL bleach earlier today. However, we just found out that it wasn't accurate at all. I had ordered a set of scientific graduated cylinders (for our homoschool) and we got them today. Using the 10 mL cylinder, we found that what we though had been 1 mL bleach was actually only a bit over half (maybe 0.6 or 0.7 mL). We are retesting the DG bleach now to see what percent it really is. Well, we retested and still got 3.5% for the DG brand.
Okay, so at 10 p.m. our FC was 13 ppm (last night). This morning at 7:45 a.m. it was 12 ppm. We only lost 1 ppm last night. This is good, right?
I think we are going to add the polyquat now.
