Results 1 to 10 of 29
Thread: How often to test & how much chlorine to add daily? Also, vacation upcoming...
    Jun 2010
    South MS
    Default Re: How often to test & how much chlorine to add daily? Also, vacation upcoming...
    Okay, numbers for the evening...
    Last FC reported on this post was 11 ppm at 11:30 this morning (Thursday). We did not add any chlorine at this point.
    At 4 p.m. today DH added 4 quarts of the Dollar General Bleach (tested to only be 3.5%).
    Unfortunately we do not know how much the chlorine had dropped before the bleach was added at 4 p.m. since I wasn't home (stuck in line at Walmart with the whole store full of registers with computers down) and DH did not test at this time.
    At 8 p.m. our FC level was 9.5 ppm. We added 2 quarts of the new bleach (Walmart brand), which should have brought our FC level to 15.5 ppm.
    At 10 p.m. our FC level was 13 ppm. Either the bleach wasn't 6% or something is eating up the bleach.
    We will test in the morning and I will post the results. Then I will probably add a maintenance dose of polyquat 60 to the pool.
    Oh, I forgot to submit this reply when I wrote it about half an hour ago. Since then, we have done the test and verified that our Walmart bleach we just bought today is indeed 6 percent. However, we think the Dollar General bleach may have gotten a bad rap due to measuring mistakes. We used a pipette we had from a microscope set to measure the 1 mL bleach earlier today. However, we just found out that it wasn't accurate at all. I had ordered a set of scientific graduated cylinders (for our homoschool) and we got them today. Using the 10 mL cylinder, we found that what we though had been 1 mL bleach was actually only a bit over half (maybe 0.6 or 0.7 mL). We are retesting the DG bleach now to see what percent it really is. Well, we retested and still got 3.5% for the DG brand.
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    Jun 2010
    South MS
    Okay, so at 10 p.m. our FC was 13 ppm (last night). This morning at 7:45 a.m. it was 12 ppm. We only lost 1 ppm last night. This is good, right?
    I think we are going to add the polyquat now.
    yes, that's much, much better!! I would think that today's loss will be less than was reported yesterday, too--but testing won't bear that out because the Polyquat will probably drop your chlorine a bit.
