Results 1 to 10 of 10
Thread: Pool Pilot Dig220 and Intermatic T10604R
    Knoxville, Tennessee.
    Default Pool Pilot Dig220 and Intermatic T10604R
    I have this timer and know I don't need the High/Low speed timer feature since the Dig220 does this but I would like to use the On/Off feature. The wiring diagrams are somewhat vague in the Pool Pilot manual and since my Whisperflo is two speed I am trying to determine how exactly to wire this from the Pool Pilot. Any suggestions would be welcome! I have had several electricians look at this and they all say the timer wiring diagram in the Pool Pilot manual can't work when it is wired up for a two speed pump unless it is set to only turn it off and on when it is on either high or low but not both.
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: Pool Pilot Dig220 and Intermatic T10604R
    I have a timer turn the pool pilot on/off. The pool pilot is controlling the 2 spd pump. The poolpilot really never turns the pump off, power is always applied. The program allows you set pump times. Example: Timer comes on at 5:30am pump runs on low speed. Pool pilot pump 1 program set for 6:00am to 7:00 the pump runs on high, then pump ruturns to low speed. Pool pilot pump 2 program set for 5:00 to 6:00pm pump runs on high, then pump returns to low until the timer shuts off at 6:30pm.
    The Poolpilot is not capable of a true 2speed control with both off. Just allows you switch between speeds.
    I just have a Intermatic 220V timer.
    I am attempting to hook mine up after the Pool Pilot.
    On page 6 of the manual it shows wiring an external timer with load out of the Pool Pilot coming off termianal positions 1 and 2.
    For a 2 speed pump the load out becomes terminal strips 5 and 6 with the low speed coming off the relay.
    It would seem logical to me that when running a two speed pump that the timer would be feeding off of terminal strips 5 and 6 in this situation as opposed to 1 and 2 as described in the top "external timer" diagram.
    Correct?
    It would also seem like this would leave the low speed of the pump continually hooked up since it would be a homerun wire from the Pilot to the Pump motor. Basically wouldn't this mean the Pool Pilot could, if programed to do so turn the motor on low speed regardless of the timer?
    Jersey Shore
    Terminals 1&2 are power input to the Poolpilot not outputs. The top drawing turns the pump and pool pilot off and on at the same time. Terminal 3 is a legs of relay that connects to termials 5 when program tells it to switch.
    Same with terminals 4&6. There is no power at 3,4,5,6 in the first drawing. The second drawing has power input on terminal 3&4 with jumper to terminals 1 & 2 to power the Poolpilot.
    Hope I didn't confuse you more. Poolsean might chime in with a better understanding.
    Ft Lauderdale, Fl
    Dave, you're doing good. Sometimes it better to hear it from someone else who has done it.
    You are correct in that the two speed pump mode does not allow an OFF position and the low speed is always defaulted unless it is programmed or boost is activated.
    Sean Assam
    I wouldn't have bought this timer had I known I was getting a Pool Pilot but that was undertimed at the time of construction so I have a high/low timer that I will never use.
    hmmm I am confused!
    Diagram 1 clearly shows load out to pump so it would appear I should disregard diagram 1 as it is only for a one speed pump?
    Let me see if this is what you mean:
    I would attach legs 1 and 2 from the circuit to the line side of the timer.
    The load side of the timer would then go to terminal connections 3 and 4 while still having the power jumpers between 1 to 3 and 2 to 4.
    The output side of the Pool Pilot would stay the same out to Pump for a two speed configuration.
    Correct?
