Results 1 to 10 of 10
Thread: Pool Pilot Dig220 and Intermatic T10604R
    Knoxville, Tennessee.
    Default Re: Pool Pilot Dig220 and Intermatic T10604R
    I am attempting to hook mine up after the Pool Pilot.
    On page 6 of the manual it shows wiring an external timer with load out of the Pool Pilot coming off termianal positions 1 and 2.
    For a 2 speed pump the load out becomes terminal strips 5 and 6 with the low speed coming off the relay.
    It would seem logical to me that when running a two speed pump that the timer would be feeding off of terminal strips 5 and 6 in this situation as opposed to 1 and 2 as described in the top "external timer" diagram.
    Correct?
    It would also seem like this would leave the low speed of the pump continually hooked up since it would be a homerun wire from the Pilot to the Pump motor. Basically wouldn't this mean the Pool Pilot could, if programed to do so turn the motor on low speed regardless of the timer?
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Terminals 1&2 are power input to the Poolpilot not outputs. The top drawing turns the pump and pool pilot off and on at the same time. Terminal 3 is a legs of relay that connects to termials 5 when program tells it to switch.
    Same with terminals 4&6. There is no power at 3,4,5,6 in the first drawing. The second drawing has power input on terminal 3&4 with jumper to terminals 1 & 2 to power the Poolpilot.
    Hope I didn't confuse you more. Poolsean might chime in with a better understanding.
    Ft Lauderdale, Fl
    Dave, you're doing good. Sometimes it better to hear it from someone else who has done it.
    You are correct in that the two speed pump mode does not allow an OFF position and the low speed is always defaulted unless it is programmed or boost is activated.
    Sean Assam
    I wouldn't have bought this timer had I known I was getting a Pool Pilot but that was undertimed at the time of construction so I have a high/low timer that I will never use.
    hmmm I am confused!
    Diagram 1 clearly shows load out to pump so it would appear I should disregard diagram 1 as it is only for a one speed pump?
    Let me see if this is what you mean:
    I would attach legs 1 and 2 from the circuit to the line side of the timer.
    The load side of the timer would then go to terminal connections 3 and 4 while still having the power jumpers between 1 to 3 and 2 to 4.
    The output side of the Pool Pilot would stay the same out to Pump for a two speed configuration.
    Correct?
    Jersey Shore
    Disregard the first two diagrams. The third one is what you want and wire the input from source (house) to the input of the timer. The load side of the timer gets wired to the Pool pilot terminals 1&2. Make sure the jumpers are done according to the instructions. Don't forget the grounds. Look over the connections on the terminal striip, see if you understand what is directed in the instructions before you do anything. If you want I'll try and get a picture of the terminal strip connections tommorrow night. My timer is mounted next to the PoolPilot, best place for it.
    Don't get discouraged, the setup works great once you get it going.
    Thanks for the help!
    Ft Lauderdale, Fl
    Only one area I would change is the connection from the Time clock to the Pool Pilot. This should go to terminals 3 and 4, rather than 1 and 2. I would jump the wires from 3 to 1 and from 4 to 2. The reason is that the main wires coming in are going to be larger than the jumper from 3 to1 and 4 to 2. This is so that the wire jumper doesn't overheat and melt down. Remember, these incoming wires should be large enough to handle the amperage requirements of the main pump. The wire jumpers to terminals 1 and 2 doesn't need to be as large as the amperage draw for the Pool Pilot (purifing) portion does not require much (1.5 amps actually).
    Sean Assam
