Thanks for the help!
Only one area I would change is the connection from the Time clock to the Pool Pilot. This should go to terminals 3 and 4, rather than 1 and 2. I would jump the wires from 3 to 1 and from 4 to 2. The reason is that the main wires coming in are going to be larger than the jumper from 3 to1 and 4 to 2. This is so that the wire jumper doesn't overheat and melt down. Remember, these incoming wires should be large enough to handle the amperage requirements of the main pump. The wire jumpers to terminals 1 and 2 doesn't need to be as large as the amperage draw for the Pool Pilot (purifing) portion does not require much (1.5 amps actually).
Sean Assam
e-mail: [email protected] --- www.autopilot.com - www.aquacal.com
I've been researching systems and I believe I will get the Dig220. After reading this thread I'm a bit confused. I have a 2 sp pump and the way I'm reading this is that the pump wont turn off, just cycle between high and low? That means it will run 24/7?
Davenj, you have another timer to control the on/off?
Also, does the Dig220 control panel completely replace my original box? I'm having problems with my current timer and switch and I'm hoping this will just be replaced with the Pool Pilot's box.
