Thread: algae growth
    May 2010
    25 Holly Lane
    Default algae growth
    New to the forum so if this is in the wrong place I am sorry.
    First time pool owner it came with the house.
    Nightmare opening algae swamp took 15 days of hell to get right but I got it by lurking on this forum. No thanks to the idiot pool co. we hired to open but thats a whole different story.
    Info- 20x40 in ground 35900 gallons
    - Sta Rite Cartridge filter
    -Aqua Heat Heater
    -Paramount in floor
    Decided to do BBB
    Todays readings from tf-100
    FC-2
    PH-7.7
    TA-120
    CYA-45
    Temp-84
    On my walk around I noticed some small algae growth by the stairs, now I realize that FC is low but it was 5 last night so I thought I was alright until I got home from work. I guess not. Any ideas on how to prevent an algae bloom would be appreciated
    Thanks in Advance
    Kurt
    Default Re: algae growth
    Hi, Kurt, and welcome to the forum!!
    The best and most foolproof way of preventing an algae bloom is keeping adequate chlorine levels in your pool. Since you see algae starting to form already, you need to shock the pool up to 15 ppm of chlorine. You need to KEEP IT THERE by testing and adding more chlorine to get back up to the 15 ppm, and do this 2-3 times daily, or as often as you can. In a pool your size, each 2 quarts of 6% bleach you add will raise the chlorine by 1 ppm, so you can use that as a guide when figuring out how much to add. The more consistent you are about maintaining that shock level, the quicker the algae will die. While you're doing this, keep the pump/filter running, cleaning it as the pressure indicates, and brush the pool at least once daily to dislodge any algae stuck to the walls and giving it greater chlorine exposure. Keep your chlorine at 15 ppm until 1) the pool clears, 2)your CC is 0, and 3) you lose less than 1 ppm of chlorine overnight when measuring after the sun is off the pool in the evening and then again in the morning before the sun hits the pool. After those 3 conditions are met, you can let the chlorine drift back down, but it should NEVER be lower than 3 ppm. It's letting the chlorine get too low that's causing the algae.
  1. Opening pool with massive algea growth
    By TomDehoff in forum Dealing with Algae & Slime
    Last Post: 06-01-2012, 06:22 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Any thoughts on fighting algae growth on Kool-Dek Surface?
    By mneal in forum In-Ground Pool Construction and Repair
    Last Post: 08-13-2008, 04:48 PM
  4. Power Powder Plus - use for spring startup and algae growth?
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-16-2007, 12:41 PM
  5. Does a solar cover help reduce algae growth??
    By MTU 5.0 in forum Dealing with Algae & Slime
    Last Post: 07-26-2006, 12:49 PM
