OK, so it is not limeade, but it sure looked that way - LOL.
I have been lurking here and have gotten quite a few tips and tricks. Thank you to all that post here.
I have been disabled due to injury for the past 6 months so therefore pool care was not an option. I am now getting around again but unfortunately, my pool demonstrates all the signs of my ignoring it by turning my once crystal blue water into, well, limeade. There was algae growing on the sides of the pool.
Here are the particulars - gunite in-ground pool, irregular shaped, approx 11,500 gallons, cartridge style water filter, chlorine tablet feeder.
I do not have a home test kit so I rely on the pool store for my numbers. So the first numbers I got were before I did anything so I could get a baseline:
FC - 0
TC - 0
PH - 7.4
TOT ALK - 100
CALCIUM HARDNESS 300
STABILIZER - 100
TOTAL DISSOLVED SOLIDS - 700
So, before reading about the downsides of the chlorine pucks here, I panicked and dropped four into the feeder to get some chlorine in the pool. I then regained my composure and started reading posts. I went to the local ALDI and bought 12 of their bottles of bleach ($1.09/ 3 quart container - Huge thanks to whoever mentioned ALDI on another thread, not alot of extra cash to be had on a disability check.) I added 4 bottles, or 3 gallons of bleach. Had the water tested the following day, and the numbers came out to this:
FC - 4.0
TC - 4.0
PH - 7.7
TOT ALK - 100
CALCIUM HARDNESS - 330
STABILIZER - 100
Of course, I was not satisfied so I added another 2 bottles (1..5 gallons) of bleach. I do not have new numbers yet, but will have them tested tomorrow when I can get to the pool store.
Needless to say I did clean the filter, brushed and vacuumed the pool.
So my concern is the creeping rise of the pH level. The pool store recommended a quart of muriatic acid (I know better from listening to you fine folks as to what to actually use - LOL). However, it has been my experience that if I start playing with pH levels to adjust it by a .1 or .2, I wind up going too far in one direction and then too far back the other way. Thoughts or suggestions?
Also, I assume my stabilizer levels are way in excess of the 100 since that is the max of the measurement, but I have learned my lesson regarding the chlorine tablets.
Thanks for putting up with my rambling post - am I on the right track, what should I do next? The water is clearing, significantly. I am still concerned about locking in the correct chemical balance though.
