Keep your chlorine up, above 0.5 and below 2.0. Go ahead and lower the pH another notch.
Don't backwash too much. Brush if you like, but unless you think you're getting algae (slick sides to the pool) I don't know that I'd bother yet, until you can see what you are doing. 1x per day should be fine.
Ben
The stains are lifting and I'd say about 90% gone. Residual markings remain around the worst areas, but the ring around the top is pretty much gone and the walls look pretty good. Keep in mind about 50% of these stains lifted after my initial 5lbs. ascorbic acid treatment.
