Results 1 to 8 of 8
Thread: Help with replacing pool light
    Long Valley, NJ, USA.
    Default Re: Help with replacing pool light
    I got it!
    Sealed it back up nice and snug and after 3 days....no water in the light.
    Thanks for all the help!
    VERY much appreciated....just saved me a $90 service call.
    Searcher...your math is wrong.
    the $ in electrical savings 500% less the cost
    you are spending 5 times less when going from 500 watt to 100 watt.
    its all good ! ;-)
    May 2010
    Asheboro, NC
    Quote Originally Posted by albertgarrido View Post
    its all good ! ;-)
    Now why did I write "at 20% less cost to run" when it is 80% less?
    Brain fog, too late at night, old age?
    Pick excuse.
    May 2010
    I got it!
    A test you should try is to run the light for a couple of hours, let it heat up, then turn it off and let it cool.
    When you turn the light on, the inside of the fixture begins to heat up. Along with the heat, comes pressure. If the seal is not good, air will begin to escape. Then when the light is then turned off, the fixture cools and the pressure subsides, and you start to develop vacuum. This is when the light fixture begins to draw water into itself.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
