My levels, are they okay?
Thanks again everyone on here for the all the help. I apologize for posting incorrectly as I have been learning. I do know you are all unpaid volunteers, and I truly appreciate your time! I know it is a struggle for me to even get time to get on here for myself. Hopefully sometime I can give back to others in turn. Anyhow, we finally changed the sand after the baq. conversion. I tested all of my levels this morning and this is what they are: Chlorine:FC-3.5, CC-0, PH- 7.6 ( I have been adding some Muriatic Acid to decrease) Alkalinity- 125 ( this is when the color turned to light pink, not bright red), Calcium Hardness- 100, and CYA is 35 (this has dropped since sand change, but seems to be where it should be?) Our pool is crystal clear and it is holding the chlorine better since sand change. How do my perimeters look? Thanks in advance for all your help, I TRULY appreciate it! I am rec. this site to many others, so they too can take over the control of their own pools, also and not be at the mercy of a pool store!
