Thread: Help with Legend II install
    Jun 2010
    Virginia
    Default Help with Legend II install
    I just received my Kreepy krauly/Pentair/Letro Legend II automatic pressure side cleaner (it is like the polaris 360 - no booster required) and "comes equipped to connect to a 1.5" threaded (female) dedicated return line". The only problem is my dedicated return is much smaller (either 3/4 or 1"). Does anyone have any experience as to how to connect? Sadly technical support doesn't seem to know...
    May 2010
    Default Re: Help with Legend II install
    Polaris makes a fitting for this. 3/4" male to 1 1/2" female, I believe it's a G-9.
    I would have to think that Pentair makes one too, but i don't know the product number.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    Jun 2010
    Virginia
    Fantastic! Thanks! I was able to find online when I added Polaris. Strangely Pentair has no such part for the Legend or Legend II that I can find anywhere. Even more strange, they do have exactly the same part listed as "pentair replacement part for Polaris Pool Cleaner" see
    http://www.pentairpool.com/pool-pro/partslists/cleaners-pentair-replacement-parts-for-polaris-pentair-polaris-cross-reference-replacement-parts-141.htm
    Their tech support knows nothing of this however...
    Thanks ton - I was considering using a mallet and cold chisel to tear out the 3/4 inch fitting and repipe - which could only end badly!
    Jun 2010
    Virginia
    Smile Re: Help with Legend II install
    UPDATE: I ordered the Polaris coupling (the part number is indeed G-9) and it works perfectly. Thanks much!
    May 2010
    You're welcome. Glad to be of help.
