Results 1 to 10 of 17
Thread: Seapool? Nope - C-Pool!
    Ontario.
    Default Seapool? Nope - C-Pool!
    Read this in another non-pool forum. Person posted about more efficient pool pumps, and I posted links to pool solutions, then this post showed up. Never heard of Seapool, and am wondering about the sanitation of what was posted there?
    my dad uses a chemical in his pool called "SEAPOOL". it is a copper-sulfate compound that replaces the use of chlorine in the pool with an exception to one puck a week in the skimmer. the advantage to using SEAPOOL is that it only requires the pump and filter to be run twice a day for 3 hours at a time. so he has it set up on a automatic timmer and as you can guess saved 75% of his electricity bill for the pool. *There is no conversion kit that is required to use this chemical, unlike a saltwater pool.*
    Last edited by PoolDoc; 07-25-2010 at 07:02 AM. Reason: Title change to correct product name
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Default Re: Seapool?
    Copper sulfate shows up in many "non chlorine" sanitation systems.
    1. It is not an EPA approved residual sanitizer.
    2. It is very slow acting and a pool requires a sanitizer with fast kill times.
    3. Copper is an efficient algaecide so the water doesn't turn green from algae so one is lead into the false assumption that clear water is sanitized water. It is not.
    4. Copper is what turns hair green and stains pool surfaces. Period.
    5. Copper sulfate is dirt cheap so companies that sell this garbage make a LOT of money.
    You nailed it, Waterbear.
    Ben
    Ben
    Aw shucks! Thanks!
    Ontario.
    I put most of what Waterbear posted as a response in the other forum, and he came back that it was his Dad that used it and he is a senior chemist at BSAF, etc., etc. I invited him to come here to discuss it but still waiting.
    Quote Originally Posted by Spensar View Post
    Tell him to tell his dad just to use copper sulfate, since that is the active ingredient and MUCH cheaper. I am sure that being a "senior chemist" he can figure out the dosage needed.
    OH WAIT, he probably does not work in water chemistry at BASF so he really doesn't have a clue except for the one he bought!
