Re: Will a sealed container of water hold chlorine forever?
Note that many water districts are switching from using chlorine to using monochloramine (which would show up as Combined Chlorine instead of Free Chlorine on a chlorine test) and this does not evaporate (outgas) very quickly. The only reason the chlorine evaporates quickly in tap water is that there is no CYA in the water -- otherwise, it would take many days to evaporate.
