Results 1 to 10 of 29
Thread: New pool owner needs help.
    Florida
    Default New pool owner needs help.
    So my husband and I bought a house with a huge hole in the backyard with a deck built around it. Amazingly, after considering the cost effectiveness of filling it in, removing the deck, and adding sod... we discovered that replacing the pool would be cheaper (and way more fun than sod!) as long as we were able to maintain it.
    One week later and we are seeing that that is going to be a tall order. Presently, I have a greenish tinge to my pool and a little bit of cloudiness.
    My first problem is that I don't have a decent test kit. After reading here a bit, I can see that its vital for me to be able to test my CYA level. The test kit we just bought at Home Depot does not do that. So, until I can talk my husband into buying me a Taylor kit, is my best bet to take samples to the pool store? Can I maintain my pool using the BBB method without it?
    HELP!
    24' AG sunken in
    approx. 15,000 gallons
    Test results
    FC: Measures below test level - my guess, .3
    CC: same as above
    pH: 7.6
    TA: 300 ppm
    Default Re: New pool owner needs help.
    Hi Shoogles, and welcome to the forum!!
    Yes, you can run the pool without a Taylor kit, although it'll be much easier once you break down and get it. For now, go to WalMart and get the 6-way drop-based HTH kit (no test strips!!). Also get several gallons of plain, unscented bleach. If they don't have the 6-way kit, then take a sample to the pool store and have it tested, then come back and post your results here. They will try to sell you a long list of stuff--do NOT buy any of it unless it's a drop-based test kit or some toy that you want. The list will probably start with calcium, which pool stores will insist that you need, but is useless in a vinyl pool.
    Have you added CYA? If not, go ahead and get the smallest container that they carry--I think it's 4 lbs. The bottle may be labeled balancer or conditioner, but look at the ingredient list--if it says cyanuric or isocyanuric acid, then that's the stuff.
    In your pool, assuming no CYA, each 2 1/2 gallons of 6% bleach will take your chlorine up to 10 ppm, which is your shock level. To get rid of the green, get the water up to shock level, and keep it there by testing for chlorine and adding more bleach to get back up to the 10 ppm as many times as possible during the day. Each 3 cups of 6% bleach will raise your chlorine by 1 ppm, so you can use that as a guide when figuring how much more to add. The more consistent you are about keeping it up at shock level, the faster it will clear. Keep the pump and filter running 24/7, brushing the pool daily. Keep an eye on your filter pressure, and clean your filter as the pressure indicates. Keep it at that level until the water clears up, your CC goes to zero, and you don't lose any chlorine when testing at night after sundown and again in the morning before the sun hits the pool.
    If you have added CYA already, test for it and let us know what it is--that may change your shock level.
    Florida
    Thanks for the reply Janet. I'll see about picking up the test kit at Walmart.
    Quote Originally Posted by shoogles View Post
    It sells in the $15 range, but it'll make it much easier to handle your pool.
    Don't wait to get the bleach in, though--if it's cloudy and already starting to look green, the longer you wait, the worse it'll get before it clears up.
    Florida
    Gotcha... I'll put the bleach in tonight.
    Florida
    Oh I forgot to ask... and this may be a dumb question, but whats the best method for putting the bleach in?
    Either pour it slowly into the skimmer while the pump is running (this is what I do) or pour it slowly in front of a return jet while the pump is running. Either way is fine.
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
