Thread: Home from vacation & pool is clear!
    Jun 2010
    South MS
    Thumbs up Home from vacation & pool is clear!
    My previous post:
    http://www.poolforum.com/pf2/showthread.php?t=10141
    Well, we made it home from vacation yesterday. In spite of the pool cover somehow falling into the pool and spending most of the week at the bottom of the pool, the pool is clear! We added some polyquat and shocked before we left, and had Matt's parents stop by midweek and add more bleach to shock again. The FC was basically zero upon our return, but DH Matt added bleach to shock level. We tested the FC two hours later & it was 13.5. We'll see how much it has dropped in the morning. Anyway, thanks so much for all the help getting through our vacation!
    Tricia from South MS
    Intex Above Ground Metal-Framed Pool 15' x 48" (~5000 gallons) installed 6/21/10, and now using BBB (well only one of the B's so far) and Taylor K-2006 test kit
    Default Re: Home from vacation & pool is clear!
    Good Job! Remember that PolyQuat DOES drop your FC when applied and you need to add more bleach 24-48 hours after adding the PQ. But it probably prevented algae from starting so it did its job.
    That's great! After it's shocked once just to catch anything that may be trying to start, you should be good to go
  1. Adding new Pool in Home
    By Voosch in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2013, 10:50 PM
  2. new home with pool
    By butterfly62 in forum In-Ground Pool Construction and Repair
    Last Post: 11-04-2011, 12:14 AM
  3. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  4. Am I on the right track? New home w/pool
    By dawndenise in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-23-2009, 04:48 PM
