You might check with Your local utility company and ask them what the freeze depth is for your area. They should be able to answer this as that is the minimum depth for Water Pipes, Fire Hydrant lines etc. to be buried in the ground. You mentioned that 1.5 - 2.0 feet of your pool is below ground. I would think that portion would not freeze. (Says the BTDG from Arizona where it doesn't freeze).
