Re: using citric acid to remove metal stains...
One more thing on the salt readings from the Autopilot vs. using a test kit. I had to look it up to make sure I hadn't "mis-remembered" that the reading will be affected by water temperature:
http://en.wikipedia.org/wiki/Electri...ure_dependence
My water is about 78-80 degrees now. I don't know off-hand what temp the SWG would have been calibrated at. I'm not too concerned about that since I can test once each spring to make sure I'm in the proper range. I really like having a saltwater pool - the reduction in maintenance is wonderful.
about 27,000 gal IG w/spa
Polaris cleaner
Autopilot SWCG
Pentair cartridge filter
