Results 1 to 10 of 11
Thread: Removing Cyanuric Acid from a pool
    Default Re: Removing Cyanuric Acid from a pool
    In other words you have 3 choices:
    1) Drain and refill to dilute the CYA to a desirable level.
    2) Learn to maintain a high-CYA pool--we have guidelines for how to do that.
    3) Allow your pool to become a smelly, mosquito-breeding algae-ridden swamp for a month and have to clean the mess up.
    Sadly, that's about it....
    2 wont work for them. They want to convert the pool into a pond with fish.
    Then I cannot help.
    This is a swimming pool forum, not a fish pond forum!
    Then I cannot help.
    Sorry, Carl, but I was just trying to get accurate info on how to remove all the CYA from my pool....not trying to turn it into a pond forum or get pond advice.
    I will test next Spring and go from there. If it's like usual, it will have all "magically disappeared" over the Winter, so I won't need to drain.
    Thanks.
    I was JOKING!
    (Could you name your fish "Sushi", "Sashimi", "Nigiri", and "Ceviche" for me?)
    Wink Re: Removing Cyanuric Acid from a pool
    I was JOKING!
    Very cute!
    Name one Lox for me!
    May 2010
    Don't forget Bacala
