Re: Vacation time what now?
Digger
What are borates? Is that Borax? How do I regulate them?
Borax is one way to get borates in your water (the least expensive but not the easieist but it's not that hard.) You only have to add them once since they are like CYA, they don't go away except by splashout or backwashing. They are also used in biguanide pools (bacqua and softswim) but at higher levels than in chlorine pools. For commercial borate products--Bioguard has Optimizer, Proteam has Supreme, Pool Life has Endure.
There are others but plain 20 mule team and muriatic acid work just as well.
LaMotte makes an excellent borate test strip that is accurate enough for what is needed.
If you want more info PM me after you get back from vacation and I will direct you to some threads that explain all about them and how to add them inexpensively with borax and acid so you can decide for yourself. It's really pretty easy.
