Results 1 to 10 of 12
Thread: Sodium Tetraborate
    Benton, La
    Default Sodium Tetraborate
    I went today to get my tap water tested for phosphates & metals. The guy at the pool store GAVE me a bucket of Sodium Tetraborate. Since it was free, I took it! After thinking about it, the name sounds familiar.
    Is this stuff the same as Borax? The brand name on it is ProTeam Supreme.
    27ft. Round AG Pool
    Indiana.
    Default Re: Sodium Tetraborate
    From Ben's Tip#2:
    Borax (20 Mule Team brand) is several dollars cheaper than a patented, branded material also containing 100% sodium tetraborate and is a good substitute for "PH-UP" -- especially in spas -- and is at least $0.50/lb. cheaper.
    Cool Re: Sodium Tetraborate
    Quote Originally Posted by bassadict69
    BINGO
    The folks at ProTeam love their borates, it seems to be their panacea for just about any pool problem (except low pH, though that's the only thing I know it works for ) In fairness, I cannot say that their products don't perform as advertised, we just started using/ carrying their line at the end of last season, so the only thing I have personal experience with is the Winter Kit (Results - the same as our regular closing chems - some pools open swampy, some slightly green, and some clear). One last thing, it isn't exactly the same as Borox is sodium deca (maybe penta?)borate... but what's a few borates between friends
    Main difference between 20 mule team and the borates sold as miracle pool additives is the price and the number of water molecules attached to the borax molucule. This just means that on a weight for weight basis one will supply SLIGHLY less borate. Their action once dissoved is indentical if the ppm borate is the same. Considering the HUGE difference in price I will stick to borax! Some of the pool additives use a mixture of sodium and potassium tetraborate but this really has no impact on it's effects. Probably more a price thing for the manufacturer.
    (Yes, I admit that I like to read MSDS for fun. You can learn a lot that way!)
    Benton, La
    This guy went on & on about how this stuff helps the chlorine to no have to work as hard...makes the water softer...helps to not dry out your skin & burn your eyes...etc...etc...etc.
    Heck it was free! So I guess it will save me a feww dollars by not having to buy Borax for awhile.
    27ft. Round AG Pool
    teja1946 is offline ** No working email address ** teja1946 0
    Question Re: Sodium Tetraborate
    I was told by our local pool store that if I used 50 lbs. of ProTeam Supreme in my 25,000 gallons pool that I would never again have the algae problem I had this spring when I opened my pool. It was green with algae floating. Does anyone think he is right?
    Quote Originally Posted by teja1946
    Teja, I'm sure lots of people think he's right - everybody at ProTeam, my boss and his wife and other lost, gullible souls. (See my response above). If you can't tell by my tone, I'm a little miffed with ProTeam (before I start flaming, I think I'll just take this line of thought to the china shop)
    Did your dealer tell you that you'd also have to add 37.5 lbs of dry acid (sodium bisulfate) along with the 50lbs of Pro Tease? That's 87.5 lbs of chems all at once!!! The ONLY things I would add over 10 lbs of at 1 time are 1) water and 2) salt, for a SWG (SWCG )!
    Between my 2 posts here, you should be able to ask your dealer a few pertainent ?s - hope you have better luck than I've had getting a straight, logical answer from him - Waste
    (look for a new flame in the 'China Shop' latter today)
    Post Re: Sodium Tetraborate
    He did tell me to add the ProTeam at 10lbs. per day along with 2lbs of PH reducer for every 10lbs. of ProTeam. I would use Borax and do this if it would prevent the green floating algae I had this spring. However a few gallons of bleach and filtering along with brushing I had the pool clear in 3 days.
    Exclamation Re: Sodium Tetraborate - a definitive answer
    Teja, in answer to your ? 'will adding borates to the pool absolutely prevent the algae,esp the floating clumps or strands?' The answer is NO! Just a couple of hours ago I opened a pool which had a thin coat of algae on the bottom and the clumps floating on the surface (however the water was crystal clear). The homeowner came out an asked why the pool was green when he had paid extra to have the 'oxygen out stuff' (ProTeam/ borates) added to the pool. On the other hand, his water tested 'ballanced', which with over 1' of rain in the past 2 weeks, was a little supprising , other folks we've opened have needed to increase both pH and alk. (Can't even do an "f-test" [statistics speak] on this 1 sample, but perhaps it does help the pool, even if it doesn't fully keep the algae at bay, and last year the pool was much further to the 'swamp side' of green than this year [and he opened 3 weeks later this year] and other pools without the borates have been much worse)
    However, I'll still refer to them as Pro Tease til I get some straight answers
    Default Re: Sodium Tetraborate - a definitive answer
    Quote Originally Posted by waste
    Waste,
    Perhaps the levels of nitrates and phosphates in the water are coming into play here. (Might be interesting to track them) If there is enough algae "food" then algae cangrow. The conept of what is the 'limiting factor' affecting the algae growth is most likely coming into play. Oxygen level of the water is just one of the factors that affect algae growth. If the nutrient levels are high then you could possibly still get some growth.
    "Food" for thought on this subject
