Results 1 to 3 of 3
Thread: Remove or not ??
    Oct 2004
    NJ, USA.
    Default Remove or not ??
    I filled my all my lines with about six (6) gallons of RV/pool anti-freeze in the fall. DO I need to pump it all out now before starting up the pump and filter? If I leave it in is there any harm? Please advise.
    Indiana.
    Default Re: Remove or not ??
    I start my pump on backwash, which pumps what's in the drain and skimmer lines out, but I don't worry about the return lines.
    Kentucky
    Even better - stary your system up with your valve on 'Waste' and send that stuff to the drain/sewer/ditch/yard.
    It's non-toxic, so I don't think there's any problem with it going to any of the above locations - including into your pool. 6 Gallons in 20,000 gallons of water isn't of any significant concern for that type of chemical. It's designed to easily degrade.
  1. How to remove oil from pool?
    By socalKC in forum Pool Cleaning: Manual or Automatic
    Last Post: 01-20-2010, 09:55 PM
  2. When should I Remove the Cover?
    By webfeet in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-24-2008, 10:31 AM
  3. Can I remove the cover and not run the filter?
    By nicole12 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2007, 04:17 PM
  4. How to remove this?
    By AndyT86 in forum Pool Equipment & Operations
    Last Post: 07-19-2006, 09:21 AM
  5. To remove or not to remove metals
    By surfacefeeder in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-16-2006, 11:54 PM
