Results 1 to 10 of 10
Thread: leak Detection dye?
    Aug 2010
    NE Florida
    Default leak Detection dye?
    Is there a "generic" Dye I can use for leak detection? thanks ...mike
    Honesdale PA
    Default Re: leak Detection dye?
    I have some fluorescent red dye tablets I scarfed from a trashcan at GE years ago. Used for stream tracing. I looked on the internet once and found dye markers that divers use so you should be able to find them at a dive shop. The tablets I have do leave a temporary stain on the liner that goes away within an hour or so. You use so little of any dye there should be nothing to worry about.
    PS: Also welcome to the forum.
    There is leak detection dye readily available from pool supplies and pool stores. It is not an expensive item.
    However it might not find you leak if it is not in the pool itself but in the plumbing.
    Honesdale PA
    That link doesn't really say much about the dye. Do you dilute it? How big is that bottle for $10 ?
    When I was chasing a leak in my deep end I know I went through gallons of dye trying to develop a technique and actually finding the cuts. The little they say tells you to lower the level to almost where the leak is. Big assumption.
    Just curious.
    I was simply providing a link to show that there is a leak detection dye available and it was not exorbitantly priced. It is actually available from several retail sources. We used to be able to get it on a day's special order where I worked but we did not stock it. I was not providing any leak detection instructions.
    Whether dye is going to help one find a leak or not really depends on a lot of factors and, IMHO, if the source of the leak is not obvious then calling in a leak detection company might be a good idea.
    Aug 2010
    NE Florida
    Thanks for the info guys ....I have some dye that is used to check for plumbing/sewer leaks that I am going to try ...I have several suspect areas ..cracks in the tile ...ect ....
