Results 1 to 10 of 14
Thread: white calcium line
    Default Re: white calcium line
    Quote Originally Posted by bradc344 View Post
    Waterbear my nieghbor just told me that my ph is running around 7.6 he has been keeping track of the number thanks akl is 60
    Depending on where your Calcium Hardness is and the temperature of your pool most of the time this could actually be too high, even with a low TA of 60 ppm. A full set of test results would be helpful.
    Jun 2010
    Portland, OR
    thanks waterbear, just wondering what my ideal numbers should be the pool is about 88 right now then in oct I turn the heater on and keep it at 86/87 then tur the heater off mid dec until the end of jan. it is a in ground 12k pebble sheen pool with a salt water system ....thanks for the help
  1. Calcium deposits on pool tile above the water line
    By cliveleach in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2012, 08:47 AM
  2. white calcium line removal
    By bradc344 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-20-2010, 11:59 PM
  3. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  4. White mold or calcium precipitate?
    By salinda in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-18-2006, 12:43 PM
