Results 1 to 10 of 14
Thread: white calcium line
    Jun 2010
    Portland, OR
    Default white calcium line
    hi just wondering what people are using to keep the white calcium line off from their pool tile it is an in ground pebble tec pool this tile along the water line but I have ugly whie line which I'm going to have blasted off this winter, the pool is in Arizona...thanks
    Default Re: white calcium line
    muriatic acid will remove it.
    It's calcium scale and basically a water balance issue. Many parts of Arizona have very hard water (as we do here in parts of Florida). You can minimize it by adjusting your water balance. It's pretty hard to do much abut the calcium hardness but it is possible to lower the total alkalinity if it is high enough to be contributing to the scaling and in most cases it is fairly easy to keep tabs on the pH to help minimize scaling conditions.
    High pH is the main factor that will contribute to scaling conditions that is easily adjusted but it is something you need to keep on top off all the time.
    However, please post a full set of test results so we can see where you are now and what changes you could make that might help prevent scale from forming as fast.
    Scottsdale, Arizona
    Mine does not get much build up but once a year I hit it with a pumas stone and it's fine.
    Jun 2010
    Portland, OR
    thanks for the answers I unfortunatly I'm not at that home right now to post the numbers I will get my neighbor to get them for me he is watching my pool. what is a good range for the ph? mine is runs around 7.4 to 7.6 . thanks Brad
    Quote Originally Posted by bradc344 View Post
    It's not where you try and keep your pH that matters, it's how high it spikes before you lower it again.
    Jun 2010
    Portland, OR
    thanks waterbear I will di a better job of keeping the ph down not sure what it was spiking to I just ordered a taylor test kit and will watch it closer ....Brad
    Jun 2010
    Portland, OR
    Waterbear my nieghbor just told me that my ph is running around 7.6 he has been keeping track of the number thanks akl is 60
    Depending on where your Calcium Hardness is and the temperature of your pool most of the time this could actually be too high, even with a low TA of 60 ppm. A full set of test results would be helpful.
    Jun 2010
    Portland, OR
    thanks waterbear, just wondering what my ideal numbers should be the pool is about 88 right now then in oct I turn the heater on and keep it at 86/87 then tur the heater off mid dec until the end of jan. it is a in ground 12k pebble sheen pool with a salt water system ....thanks for the help
    Jun 2010
    Portland, OR
    Free chlorine. 5
    Total avail chlorine. 5
    Ph. 7.6
    Total alkalinity. 120
    Cyanutic. 80
    Phosphates. 20
    Salt. 3400
    hi, these are my numbers my neighbor just sent me thanks ...Brad
  1. Calcium deposits on pool tile above the water line
    By cliveleach in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2012, 08:47 AM
  2. white calcium line removal
    By bradc344 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-20-2010, 11:59 PM
  3. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  4. White mold or calcium precipitate?
    By salinda in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-18-2006, 12:43 PM
