Results 1 to 10 of 16
Thread: T Cell 15 bad?
    Largo, Florida
    Default Re: T Cell 15 bad?
    Yup, that's the pool store I use. I didn't name the name because I thought I read a rule against that on the TOS when I signed up. I'll pick up some of those test strips, but I already added about 20lb of salt. Even if the store's salt reading is accurate and mine is not, I don't expect 20lb will raise it above the max level the chlorinator says is OK.
    As for the board replacement, I did it myself. I don't really know anything about pools, but I do have a degree in electronics. I'm confident I installed it correctly, but I suppose it's possible it could be defective.
    I need to find some kind of wooden or plastic device to try and scrape the cell as the manual suggests, I just don't have anything non metallic that can get in there, so I've just been using a hose with a jet nozzle, and the acid dip for a few minutes. Also, a few inches of the cell didn't get dipped because the manual warns not to get the part where the cord connects into the acid wash.
    How long should I expect it to take before I start seeing the reading increase some after adding salt? I do have the generator switched "off" but I assume having it plugged in will allow it to refresh the reading?
    Quote Originally Posted by kelemvor View Post
    Ben and mods, correct me if I am wrong but I do believe that it is ok to mention a store if you are not trying to promote the business but merely saying where you got a product. Even mentioning products can be against the TOS if they are mentioned to promote them but if you are listing the things you put into your pool (which is often necessary to get help with a problem) and not saying "Product X is a miracle that cleared my pool, saved my marriage, cured my dogs cancer, and brought about world peace" then I think you are OK.
    Mod or Ben, please clarify if I am mistaken.
    I know that many of the mods on here have mentioned Leslie's as a source for test kits (and also various online retalers).and Pinch a Penny is the Florida equivalent of a Leslie's store,which we don't seem to have. At least I have never seen one in S. Fl, N. Fl, on the Gulf coast, or on the east coast.
    The are talking about the connector that connects to the control box.
    This webpage might help
    http://www.goldlinecontrols.com/Support/Tips.aspx
    If you want to spend the rediculous amount they charge for the 'cleaning stand' here are instructions for it's use
    http://www.goldlinecontrols.com/Supp...ell_maint2.pdf
    One of our regulars on here, Waste, who is a pool professional said that he uses and expansion plug to do the same. (the plugs used in winterizing if I am not mistaken.) I have never tried this and just use the bucket.
    Do not dispose of the acid in the pool since this will just put the calcium back into the water. I neutralize the acid with some soda ash (doesn't take much) or baking soda (takes quite a bit and foams) and then flush it down the drain once the pH is fairly neutral..
    It's fine as long as you're not selling for the business....see my post #3 in this thread http://www.poolforum.com/pf2/showthread.php?t=10306
    Largo, Florida
    Got the strips. They read about 3800 I'll give the cell another good washing tomorrow (after I come up with some kind of large toothbrush or something for the inside. Unfortunately I can't find the site I thought was selling the cells for 300 bucks so it appears I'm on my way to another $500 purchase unless I get lucky with cleaning this thing.
    Largo, Florida
    Good news for me; I was misreading the strips! I tested 3 times with the strips and consistently get about 2750 for the salt reading, and the cell is reading 2600. Seems close enough for government work to me, do you guys think that's an acceptable range for error there?
    I got an "open" bag of salt from leslies when I went to get the strips (there was one local, after I checked the website. I like the staff at pincher penny better, but I digress) which I got for about 5 bucks. I'm gonna let the pump take a break tonight and put some more in in the morning.
    Oh, one more question. Could the flashing "check cell" condition (reduced efficiency is what the manual says) be caused by the low salt level (also flashing), or does the check cell indicator not get affected by the low salt.
    Actually, about 800 ppm difference is 'in range' You are fine.
    Yes, a low salt condition can actually case premature cell failure so the system will shut off if the conductivity is too low (not enough salt or water is too cold.)
    Largo, Florida
    Oh Joy Oh Joy, at 2800ppm (reading from the panel) The system seems to be happily generating!
    Where do I send the beer, waterbear?
