Results 1 to 10 of 16
Thread: T Cell 15 bad?
    Default Re: T Cell 15 bad?
    Quote Originally Posted by kelemvor View Post
    Good news for me; I was misreading the strips! I tested 3 times with the strips and consistently get about 2750 for the salt reading, and the cell is reading 2600. Seems close enough for government work to me, do you guys think that's an acceptable range for error there?
    Actually, about 800 ppm difference is 'in range' You are fine.
    I got an "open" bag of salt from leslies when I went to get the strips (there was one local, after I checked the website. I like the staff at pincher penny better, but I digress) which I got for about 5 bucks. I'm gonna let the pump take a break tonight and put some more in in the morning.
    Oh, one more question. Could the flashing "check cell" condition (reduced efficiency is what the manual says) be caused by the low salt level (also flashing), or does the check cell indicator not get affected by the low salt.
    Yes, a low salt condition can actually case premature cell failure so the system will shut off if the conductivity is too low (not enough salt or water is too cold.)
    Largo, Florida
    Oh Joy Oh Joy, at 2800ppm (reading from the panel) The system seems to be happily generating!
    Where do I send the beer, waterbear?
    bump the salt up to 3200 ppm
    St, Augustine.
    Or, you can send it to Louisiana and I'll send him whatever's left!!
    or, you can send it to louisiana and i'll send him whatever's left!!
    janet
    POOL PARTY at Janet's!
  1. AutoPilot Dig 220 Low Amps-Cell?/Check Clean Cell
    By tthurman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-01-2014, 08:41 PM
  2. New T-CELL-15 reading lower salt than 7 year old cell
    By sharknj in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2013, 10:00 AM
  3. Help needed in replumbing a new AquaPure style 3 port cell into old 2 port cell space
    By Anonymous European in the US in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-27-2012, 01:06 PM
  4. How to read lcd t9 cell
    By bigd4u in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-30-2012, 04:05 PM
  5. SWG Cell.
    By caustik in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-20-2006, 08:17 PM
