Thread: Pool Heater Making Strange Sound
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pool Heater Making Strange Sound
    Given your problems with the filter, it is probably a good bet you have the same issue with the heater. So I suspect there is probably some calcium buildup in the exchanger and it just needs to be cleaned out. However, you may need to do a bit more than a simple hose off. Check your manual for instructions but mine suggests using a long cylindrical metal brush to clean out the sediment.
    Mark
    May 2010
    You guys are probably right.
    But in another circumstance, there is the possibility that one of the by-passes, the flow, or the thermal, that could be the cause of the boiling. This will usually cause the heater to short cycle.
    My money is on the calcium.
    I post this for others that may have a similar issue without the water chemistry problem.
    "Just a clown talking, ignore him. "
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    May 2010
    Quote Originally Posted by Pool Clown View Post
    It's not short cycling....I ran it Saturday all day and it ran fine, over 8 hours it raised the water temp probably 10 degrees (about 10000 gallons). It started right up and I checked it everyone so often, the fan and burner stayed on and ran with no issues. It just sounded like an old boiler, making these knocking sounds like a rock or something is in a pipe.
    The season here in NYC is almost over - that is, 2/3s of the kids are back (away) at school already and my 3rd starts in a couple weeks. So once I close up in the next couple of weekends, I'll take the heater into my workshop and take it apart and report back on my findings.
    Thanks again,
    Phil
