Thread: Cloudy water & filter on-off time
    May 2010
    Illinois
    Default Re: Cloudy water & filter on-off time
    That was my 1st thought. I've been adding 1 to 1.5 gal bleach every day & the Cl level is usually btwn 2 & 5 before I add it.- I don't *think* that's it. The reason I was leaning that way is that I've had the pump on 24x7 the last 2 days & now the H2O is clear. Who knows. Just was wondering. The water looks great now & tests fine. I know w/ way high CYA to keep the CL 10+ I'll just keep playing around w/ Cl & filter time & see what works.
    If your CYA is actually 100, then anytime you let the chlorine drop below 8 ppm you're opening the door for the algae. I would shock the pool. I really think you're just wasting money to run the pump/filter more than 12 hours daily unless it's a really undersized pump.
    May 2010
    Illinois
    Cool. Thanks. I'll try & keep the CL higher - right now the pool is nice & sparkling...
    (I've got the pump off)
