Re: Trying to raise ph adding 20 mule team borax
Melanie,
How's your chlorine(does it keep dropping), CYA, and TA levels? How big's (gallons) your pool?
You could try mixing pool water and tap water at 1:1, 1:2, 1:4 ... until you get a clear reading to see if your pool water increases or decreases your tap water's PH.
Reason: re-read original post
