Thanks again to this great wonderful site. I have an issue with algae-due to my hectic days and well, er laziness- but what kind I do not know. It is dusty and brown/orangish looking while sitting on the bottom, but when I brush it, it clouds up green? Is is dead algae? Is it yellow mustard algae? Or both? Maybe I'm just colorblind? The water looks pretty clear until I brush, then I can definitley see that it is not clear. Earlier I had a sparkling picture perfect pool. Confused as all get out. I basically just want to kill it with out killing the pool and it's about time to take it down, since it's a blow up ring pool. 3600K. CYA is only around 20 (and our bathing suits show it too) and that is a guesstimate. Lots of run-ons, sorry. Ph bounces a bit, but that is because I have high alkalinity. I add muriatic when necessary, but I keep hitting it with bleach and I know that messes with the PH. I use dropper tests, doesn't show CC. And quite frankly, I did better with the dip sticks than I do with this dropper test (ack I know, I'm just telling the truth).
Thanks again, Bree![]()
