Results 1 to 10 of 31
Thread: Newbie w/ very GREEN pool - HELP!!!
    Aug 2010
    Central PA
    Default Newbie w/ very GREEN pool - HELP!!!
    I have a 24' above ground, vinyl, 4.5' deep pool (13,5000 - 15,000 gal.) with a sand filter. We moved last fall so this is all new to me. Trying to learn fast, because it suddenly turned very green!
    Just purchased a Taylor K-2006 kit.
    8-11-2010 test results: midmorning
    FC 3.6 ppm
    CC 0.4 ppm
    CYA 100
    pH 7.9
    TA 170 ppm
    Last evening after sweeping, dumped in 4 jugs of Chlorox (6%) = 5.68 gal. That was my best guess for shocking levels after looking at the 30 ppm super shock for algae removal table in the kit booklet. It didn't give guidelines for 6%. I also added water from the outside spigot because water was almost too low to run filter. And it rained last night.
    8-12-2010 test results: morning
    FC 16.2 ppm (had a little difficulty w/ this test: couldn't get water to look totally colorless. the 16.2 mark was where it looked almost clear, but as I kept adding drops it turned peach color. so I didn't get a CC reading)
    CYA 90
    pH 8
    TA 180 ppm
    Filter has been running nonstop since it turned green.
    Did I put enough chlorine in last night for a super shock? From reading I think my CYA is a big problem. And I've read to empty half the pool. Honestly I really don't want to do that. Any other ways?
    What's my next step?
    Aug 2010
    Central PA
    Default Re: Newbie w/ very GREEN pool - HELP!!!
    8-203-2010 I had my water tested by a pool store. Here is their results:
    FC 1.9
    TC 3.3
    CC 1.4
    TA 167
    pH 7.6
    CYA 32
    Did add some dry acid and then the second time several days later. Dry acid may have been old product, was here when we moved. Tuesday morning (I think) I dumped in a 1.42 gallon jug of Chlorox. Wish I had posted on here sooner and got to working on my problems faster. Is my CYA testing way out of whack or can it jump like that from not doing anything? Do you need more history from earlier this year?
    Hello gettinthesplash,
    Welcome to the forum!!
    I'm assuming that you've been using either trichlor pucks or dichlor shock to chlorinate your pool, which is why your CYA level is so high. Most people don't realize that the higher your stabilizer (CYA) gets, the higher levels of chlorine you have to keep in the pool to compensate for them. With a CYA of 100, you need to be keeping your chlorine levels at an absolute MINIMUM of 8 ppm, your target range is 8-15 ppm. When you shock, you need to get it up to 25 ppm. In your pool, the 5.5 gallons of bleach should have gotten you up to the 25 ppm, but you have to MAINTAIN that 25 ppm in order to clear the pool up. You do this by testing and adding whatever amount you need to get back up to the 25 ppm mark, as many times a day as you can. Each quart of bleach should raise your chlorine by 1 ppm, so you can use that as a guide when figuring how much to add to get it back up to the 25 ppm level. It is consistently holding the pool at shock level that will kill and clear the algae. If you shock it and let the chlorine just come down again, you're wasting your time and bleach, because it takes sustained shock levels to kill the green. Also the pump needs to be running 24/7 with an eye on your pressure gauge, cleaning the filter as necessary, and brushing the pool at least once daily. You need to hold the shock level until 1)the pool turns blue and starts to clear, 2) you have zero CC, AND 3) you don't lose any chlorine when testing at night and again in the morning before the sun hits the pool. At that point you can let it drift back down to the 8-15 range, but never below 8--at least not until you're ready to drain and refill part of your water to make the CYA more manageable. (And BTW, I would trust your CYA testing over the pool store's testing--the only way for it to drop from 100 to 32 is with major replacement of water). I definitely wouldn't use anymore trichlor or dichlor in this pool, because it's just going to drive your stabilizer higher--you'd do better to switch to just plain, unscented, generic bleach.
    Just curious, why add the dry acid? Your pH is okay where it is....
    May 2010
    Route 100
    Also, just to be sure you are at 100ppm on CYA, try to dilute your pool water 50/50 with bottled water and repeat the test. There is a good chance your CYA is above 100 ppm, which would make shocking very difficult.
    Moderator at another pool maintenace forum
    24' Round AGP, SWG, 0.5hp pump, 250lb sand filter,
    Aug 2010
    Central PA
    I'm sorry for the typo. The pool store test date was 8-03-2010
    Aug 2010
    Central PA
    I put in the dry acid because my TA was high. And for clarification, the pool store test was done a week or so before I tested. The end of July we were away for 4 days. Water looked good except for being cloudy. We had a solar cover on and put 5 pucks (trichloro-s-triazinetrione) in the dispenser. Husband said it looked fine right after we got back, but in a day or two it was definitely green. Then I took it to be tested at the store. Yes, we've been using trichloro granules.
    Your TA is a little bit high, but in a vinyl pool, is actually okay where it is, for now....the green water should be much higher on the priority list!
    The CYA is a very subjective test, and because it relies on turbidity for results, an algae outbreak can definitely affect the reading. So can reading the test without letting the sample sit for a few minutes after mixing with the reagent. So can reading the test in dimmer lighting than the previous time. See what I mean? So....the best you can do right now is base your shocking on the higher CYA level, and then test for CYA again after you get the pool cleared up. The key is going to be getting that chlorine up to 25 and keeping it at that level until the algae dies off. You'll know you're getting there when your water goes to blue-cloudy, which will be the dead algae that needs to be filtered out.
    As I said in my above post, I definitely wouldn't use any more stabilized chlorine in this pool. You didn't list a hardness reading--too little hardness in a vinyl pool is irrelevant, but if you really want to continue to used powdered chlorine, then you may be able to switch to cal-hypo granules for a little while, depending on your current CH level. YOu can't let it get too high, though, especially with TA and pH on the higher side because it can contribute to cloudy water. I would just use bleach, personally--it gets the chlorine in the pool, and doesn't add anything else that you have to watch out for!
    The
    Aug 2010
    Central PA
    Thanks Janet for all your advice. I plan to stick to the bleach and get rid of the other chlorine. Gonna go do some more testing and probably add some more bleach and see if I can keep the level up where it needs to be.
    Aug 2010
    Central PA
    Just tested again:
    FC 16.0
    CC 1.0
    Added 9 qt. of bleach. Gonna do all I can to get rid of that ugly green!!
    May 2010
    Route 100
    To speed things up you may want to consider a partial drain and fill to lower your CYA level. Battling algae with CYA at 90-100 will be very difficult. It can be done, but you are going to need a ton of bleach/liquid clorine to maintain that high of an FC
