Janet,
It's green and cloudy
Janet,
As I stated a few days ago, trying to shock your pool with CYA at 100 is very difficult. You can try to keep at it by raising your FC level further to let's say 35ppm and holding it there or I would strongly encourage a 50% drain and fill to get the CYA down.
Moderator at another pool maintenace forum
24' Round AGP, SWG, 0.5hp pump, 250lb sand filter,
I agree with dmanb2b, your CYA may be well above 100, can you try diluting your pool water 1 to 1 with distilled (maybe even tap) and test the dilute sample for CYA, if it's still 100, dilute 2 to 1 etc. until you get a reading within the range of the test. The accuracy of this testing will be lower but you'll have a target for the partial drain / refill you'll need. There are some postings on this forum that describe using a plastic membrane to fill while draining without risking the integrity of your pool or wasting fill water.
It's starting to clear up! Can faintly see the bottom and it's changing to blue.
Good work!! Keep that chlorine up above your shock level, keep the filter running, and clean/backwash it as your pressure indicates. Sometimes it takes awhile, that's why one of the most important ingredients is POPP (Pool owner patience and persistence)!
Hang in there...
It's definitely blue now!! Am I right that I need to keep it at shock level until the ppm doesn't drop over night? not even 1 ppm? and CC at 0? anything else? To others dealing with algae and high CYA, definitely replace water if you don't have lots of patience and want to go swimming ASAP. According to my testing, my CYA has dropped to 60. The only "replacement" I did was backwashing and adding water to keep pool full, plus rain. Lately we've been keeping the FC @ 30 - 35 ppm. Even with diluting I could never get my CYA to test more than 100, but it sure seems like it could have been. I've been really busy and away some days so didn't always keep real close tabs on my FC levels and it dipped some. I'm sure that attributed to how long it's taking to clear it up. Feels pretty good to see progress!! Thanks everybody for your help! I really appreciate this forum.
Glad to hear you're getting some results!! You're right--maintain your shock level until the CC is zero, the water is clear, and you're not losing more than 1 ppm of chlorine when testing at sundown and in the morning before the sun hits the pool. When you reach that stage, and let the chlorine drift down, remember that with a CYA of 60 you're still going to have to maintain a minimum chlorine level of 5-10. I would try to keep it around 7-8 just to be on the safe side and give yourself a little wiggle room in case of a rainy day or forgotten dose of chlorine.
Good job!
