Thread: Liner Replacement
    May 2010
    20446 Fairview Dr.
    Default Liner Replacement
    My in ground Gunite pool liner is 12 years old, some areas are rough and some are itched where algae is a problem. I'm thinking of replacing the liner. What is the best way? resurfacing the pool with another gunite or there is something else new and improved?
    Any advise from anybody? Pebble tech is too expensive, what about Diamond brite? I hear is rough on the skin.
    Default Re: Liner Replacement
    Hi, staclear. I deleted your other post since it was a duplicate. I assume that when you posted, it didn't show up so you posted again. Remember, posts go to a moderation queue and have to be read first by one of us before they show up on the forum so if you post, sit tight. One of us will be along shortly to mod it in.
    I can't help with your problem, but somebody will be able to. Good luck.
