Results 1 to 10 of 11
Thread: Cloudy Water
    Fredericksburg, Virginia, USA.
    Default Re: Cloudy Water
    If you are using a Kit bought from here, then a full tube on a CYA test and you can still see the black dot means you have no measurable CYA.
    One of the few ways to lower CYA is to let you pool get the condition you opened to. Go to the Pool store, Lowes, possibly Walmart and buy Stabalizer, this is CYA. Add the recommended amount on the bottle to get you to your preferred level based on the gallons in you pool.
    I have a saltwater pool I prefer to run 40-50PPM CYA, others like something closer to 20-30 or 30-40. When I add CYA I put it in an old nylon stocking from the wife and hang it in the skimmer until it disolves. Other wise it just winds up in the filter and you backwash it out if you don't give it a week or so to disolve.
    In the meantime you need to get a sustainable FC reading above 10 and keep it there unitl all the algae and cloudiness are gone and if possible a day or 2 beyond. Keeping a minimal Chlorine level of 4FC or less is just inviting the algae to startup again. The DE in the filter is helping you filter out the dead algea that is causing your cloudiness, but you current CL reading with no CYA means you are at risk of a new algea outbreak at any time.
    Was reading elsewhere on the boards. PoolDoc always explains these things the best. Take a look at this thread for more information on your CYA loss: http://www.poolforum.com/pf2/showthread.php?t=1001.
    NW Arkansas
    Question pls: What is DE and where do I obtain this? I also have sand filter, IG vinyl and cloudy water after keeping the Cl high. Thks.
    Roseville, California USA.
    DE = Diatomaceous Earth
    Here is link which describes what it is:
    http://en.wikipedia.org/wiki/Diatomaceous_earth
    From the link:
    "The most common use (68%) of diatomaceous earth is a filter medium, especially for swimming pools. Diatomaceous earth has a high porosity because it is made of microscopically small coffin-like hollow particles. It is used in chemistry as a filtration aid to filter very fine particles that would otherwise pass or clog the filter paper. It is also used to filter water and other liquids such as beer. It can also filter syrups and sugar. Other industries such as paper, paints, ceramics, soap, and detergents use it as a filling material."
    So for pools we use as a filter medium. For sand filters you can add a small amount which increases it's ability to filter smaller partcles. Here is a post describing how to do it:
    http://www.poolforum.com/pf2/showthread.php?t=515
    scroll down to post #6.
    You can purchase DE at most stores that carry pool supplies or online.
