Re: Pump still running but no longer moving water...
Janet, Go and get a small mirror. That will possibly save some time. Use it to look at the inlet of the impeller to see if anything is in there. You may need a flashlight too. The smallest part in the impeller vanes is right at the inlet. If you have a blockage, you should be able to see w/o taking apart the pump.
Did you check and make sure that the weir (door) in the skimmer moves freely? If it gets stuck "up", the pump will drain out the skimmer, and give the symptoms you describe.
4 out of 3 people have trouble with fractions.
Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
