Re: proper equipment?
Hi,
If I remember correctly, the 244 uses either 200 or 250# of sand. If so, it should be just fine with a 1 hp superpump, though you could probably use a 3/4 instead.
But the noise: Is it simply a loud motor or is there some other sound associated with it? How loud is "loud"? My 2speed super at full power is far louder than at low speed, and you can hear it from pretty much anywhere on my deck, but it's not annoying. Low is nearly silent. Is is vibrating from not sitting on its base evenly?
You can get noise from air in the pump's skimmer basket, or from other causes. Al (Poconos) and some of the others may be better at diagnosing it than me.
