Did you soak in a degreaser before you soaked them in acid? If not you might have hardened the organics on the fingers into an insoluble 'cement'. You can try using a filter cleaner or TSP to soak the fingers but it might not help now. Since you said "fingers" and not "grids" I assume this is a bump type filter and not a backwashing one, correct?
