Thread: hth 3 in 1 tabs
    Default hth 3 in 1 tabs
    hello all, ive aquired some of the hth 3 in 1 7 day skimmer tabs from a friend that no longer has a pool. they are the calcium hypo tabs not the trichlor tabs and they are 3 inch tabs. my question is can i use them in a floater instead of dropping them in the skimmer. the reason i ask is because they are supposed to be 7 day tabs but in the skimmer they only seem to last 1 1/2 days. any help would be appreciated. thanks
    Default Re: hth 3 in 1 tabs
    I would ONLY use them in a new floater that never held Tri-Chlor tabs. If they are the ones that are NOT encased in a plastic shell, they are lousy performers, as you said, only lasting a day and 1/2, if that, in the skimmer.
    But, as long as your calcium levels aren't high you can use them.
    ok thanks, they are the regular pucks that are not in the plastic shell
    waterbear's Avatar
    St. Augustine, Fl
    If you check I believe you will find that they contain copper. Read the ingredients.
    Quote Originally Posted by waterbear View Post
    Eeww!
    The ones I once had did not. But HTH is big on selling combined stuff that makes you THINK you are taking care of multiple issues at once, but actually adds to the problems.
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by CarlD View Post
    Eeww!
    They had both kinds at one point. Not sure about now but the ones we sold did contain copper.
