Results 1 to 10 of 18
Thread: New Pool Owner
    Default Re: New Pool Owner
    I suspect that all the Borax you put in finally caught up, but I'm glad it finally got up to where you need it to be. As long as it's staying in the 7.2 to 7.8 range, it's fine for swimming. As far as chlorine goes, the kids could safely swim in a pool with chlorine up to 15 ppm (but I'd wear old suits in case of fading) because your CYA is so high. You say right now it's off the charts, but I don't know how high that is. Here's a link to the Carld shotglass method to force your OTO kit to measure higher levels of chlorine so you can get an idea of where you are.... http://www.poolforum.com/pf2/showthread.php?t=10073.
    With your CYA that high, you definitely do NOT need to use anymore trichlor pucks or dichlor powder, and I strongly advise you to drain about 1/2 your water and refill, to bring that CYA down to a more manageable level, if that's at all possible.
    Aug 2010
    Central Texas
    OK...thanks to this forum, my pool looks great. TC has come down to around 6ppm and ph is holding steady around 7.2. With it being so close to end of season, don't think I'll do a drain right now. I will just live with the high CYA and try to manage the TC and ph. What would my ideal TC number be with my high CYA level?
    BigDave's Avatar
    Post Re: New Pool Owner
    bobcat,
    It sounds like your CYA is well over 100, you'll need at least 8ppm FC to keep your pool safe.
    Ben's Best Guess Chart: http://www.poolforum.com/pf2/showthread.php?t=365
    With your CYA halfway to the 100 mark, it's just a guess at this point--but I would say your CYA is somewhere around 150. I would keep the chlorine ABSOLUTELY no less than 8 ppm but would target somewhere closer to 10-12 at a minimum.
    Glad it cleared up--enjoy the rest of your season!!
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. new pool owner
    By bingusboy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-12-2006, 03:39 PM
