Thread: Borax & Autopilot
    Dec 2005
    Default Borax & Autopilot
    About 3 months ago, I replaced the ORP sensor on my PoolPilot. About 2 months ago, I put Borax into my pool as a buffer. Right after doing that, my ORP sensor says "right on" number-wise, but a chlorine test shows no CL in the pool. I bumped up the ORP target on the system, and it makes more CL now (still pretty low), but over the last 2 months, I have been getting algae "spots" on the pool in different areas. These are not going away, but multiplying.
    My main question is - does adding Borax throw off the ORP sensor? I know that it is an algaecide itself, but not sure why the AutoPilot is having issues after the add. Am I OK to just bump up the ORP target on the system?
    Thanks for the help!
    -randy
    Default Re: Borax & Autopilot
    ORP controllers are tricky at best and, IMHO, really do not belong on a residential pool since proper setup, calibration, and maintenance of them requires specialized training.
    Just my 2 cents.
    Dec 2005
    Well, the AutoPilot / PoolPilot has been on the pool for 3 years, and runs well, but the Borax is new... I was hoping for an answer on whether the Borax had an impact on its readings?
    Thanks!
    -randy
    I would be more suspect of the electrodes. They do need to be replaced on a regular basis.
  1. New Autopilot
    By NBWS6 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-29-2007, 12:13 PM
  2. Autopilot TC
    By jaypool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-02-2006, 12:40 AM
  3. New AutoPilot help
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2006, 10:06 PM
  4. Autopilot SWG, Ph and TA
    By SoCalBoo in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-17-2006, 07:48 PM
  5. Autopilot
    By Ciscokid in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-23-2006, 02:43 AM
