Pr0team has been recommending 2 lbs per 1000 gal on the container since the days of Supreme (which needed the acid added). It gets you to about 30 ppm. 30 to 50 ppm is considered the optimal range. If you have a backwashing filter then shoot for 50 ppm since the level will drop with each backwash. If you have a cart your levels will not drop as fast (but 50 ppm is still fine to shoot for if you don't mind the expense. The 30 ppm recommended on the label is more of a marketing thing than anything else to make the product appear less expensive than it really it and 50 ppm is better.
