Results 1 to 9 of 9
Thread: Blue calcium??
    Jun 2010
    Louisiana
    Default Blue calcium??
    This customer called me and wants me to take a look at his pool. He says he has blue spots at the bottom of his pool. I am guessing it's calcium, I have not seen the pool yet and I don't know what the chemical readings are. I am going over there Friday but I was wondering what you guys may think it is and how to get rid of it. I will take some pictures of the pool Friday and post them.
    Crystal Clear Pool Service, LLC
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Blue calcium??
    Calcium would not cause blue spots. Scale is usually white to tan. Blue is caused by copper. Period. End of story. It would be possible for copper stains to form on existing scale, however.
    Sources of copper can be algaecide, heat exchangers exposed to low pH (usually from use of trichlor), the use of ionizers and "mineral' systems (ecosmarte, ClFree, Nature2, Poolfrog) or copper based "alternative sanitizers" (Pristine Blue, SimplyBluePool), copper pipes, and even the fill water itself.
    Jun 2010
    Louisiana
    The customer does have a heater and have never used any kind of metal sequestering agent.
    What is the best way to get rid of the copper stains?
    Thanks.
    Here's the link to Mbar's ascorbic acid treatment to remove metal staining:
    http://www.poolforum.com/pf2/showthread.php?t=7923
    Don't know if there's a better way specifically for copper or not, hopefully one of the stain "experts" will chime in....
    Jun 2010
    Louisiana
    I just finished up at the customers house. I tried putting the asorbic acid on the blue stains and it did not do anything. I really think it's the plaster itself that is screwed up I will upload some pictures when I get home. Hopefully the pictures came out good enough.
    Jun 2010
    Louisiana
    Here are some pictures I have taken, it might be kind of hard to see the blue spots on the plaster.
    The pool was re plastered about 4 years ago and it looks this bad?
