Thread: pressure too high
    Aug 2010
    new jersey shore
    Default pressure too high
    I took filter apart and cleaned everything but pressure starts out at 27psi and then goes to 30-31psi and the water stops moving. filter is clean. this a DE filter. pool turned green from lack of filtering. any ideas.
    Scottsdale, Arizona
    Default Re: pressure too high
    Better experts than I on here but it sounds like something is clogged.
    Hopefully one of the experts in this area will be by soon, but I'm betting with Phillbo, sounds like something on the suction side is stopped up.
    mas985's Avatar
    Pleasanton, CA
    Sounds like a filter issue to me. DE grids have a tendency to cake up and clog especially if you are fighting an algae bloom. When you cleaned the filter, did you also soak the grids?
    Also, a normal filter pressure of 27 PSI is a bit on the high side. Is that with solar? What size is your pump, filter and plumbing?
    Mark
    Scottsdale, Arizona
    My DE normal pressure is around 12 psi.
    May 2010
    If you wanted to check and see if it is the grids, take the grids out and put the filter back together, switch your valves to spa. Start the filter, bleed the air, and note the pressure.
    Note: when you do this, you are likely to get a bunch of D.E. back to the pool. Thats why you switched the valves to spa, to keep the mess contained. When the filter is reinstalled, just drain the spa (draw from the spa, and return to the pool), and the filter will catch all the mess.
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
