Re: Variable Speed Pump VS 3050---gpm/rpm?
The Intelliflo is both a variable speed pump as well as a variable HP pump. Changing the speed, changes the braking HP of the motor. So in effect, it can emulate any pump on the market at any speed and usually, at better efficiency. While it is true that top speed is the equivalent of a 3 HP pump, nobody said that it ever needs to be run that high and it was probably not necessary during the start up.
