Results 1 to 10 of 12
Thread: Pole Recommendation Needed
    Default Pole Recommendation Needed
    Hi all,
    We need to replace our telepole. I'm sick of buying cheap ones that just end up breaking. So I've decided to get a Skimlite brand pole and wonder if anyone has had experience with them.
    I can't decide between the 9016 Dually here:
    http://skimlite.com/9000.html
    or the 3500 Durapro here:
    http://skimlite.com/3500.html
    I was concerned about the 9016 being too heavy, but according to Skimlite, the 9016 weighs 3.25 pounds & the 3500 weighs 2.75 pounds. I like that both these poles have dual locks and the locking mechanisms are replaceable, if needed.
    Inground 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWG
    Default Re: Pole Recommendation Needed
    Just out of curiousity, what does it take to break a pole? We've still got the original one that we got when our pool was built 8-9 years ago, and I can't imagine any pool chore putting enough pressure on it to make it bend, let alone break?
    Hi Janet,
    I probably should have explained better. The pole itself doesn't break, but rather the locks. So when you're vacuuming for instance, the pole will collapse because the lock is broken. I think they're just made cheaply and that's why they break. So I said the next pole we get is going to be a good one, lol.
    Wow, yours has lasted a long time. It must be a good brand.
    Scottsdale, Arizona
    Do you store your poles in the sun ? The locks are typically plastic and will get destroyed by the sun.
    We have a chain link fence that has a sort of long pocket attached to it that holds all the poles. It gets sun for a few hours in the afternoon. Thanks for the reply, and definitely something to consider when I order my new pole. Maybe I can make some kind of top for the pocket to keep the sun off of it.
    Quote Originally Posted by mickey4paws View Post
    The label on it says " Pentair Metal Cam Telescopic Pole".
    The people who built my pool furnished it instead of their standard startup chemical package, when I told them I didn't need anything that was in the package. Fortunately, I had found this site about 6 months earlier and pretty well understood the chemistry issues before we got to that point.
    That was smart to get the pole instead of a bunch of chemicals you didn't need
    I wish our local pool store sold decent poles. One time I bought one there and took it home and started using it. Ended up with blue hands from the paint on the pole.
    I ended up ordering the Dually pole made by Skimlite (9016). It's probably more heavy duty than I need but wanted to go with something that will hopefully last. Plus, if the locks do break, they are replaceable.
    Let us know how it works out for you--that may be some useful information for somebody else when the time comes.
  1. Telescoping Pole - repairs
    By rrwcm in forum Pool Equipment & Operations
    Last Post: 03-28-2009, 04:52 PM
  2. Cleaning metal ladders/pole
    By jawman in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-30-2007, 05:33 PM
  3. Pool Pole
    By SJohnson in forum Pool Equipment & Operations
    Last Post: 11-28-2006, 11:22 PM
  4. Looking for a give-it-hell pole
    By Unabomber007 in forum Pool Equipment & Operations
    Last Post: 08-01-2006, 11:06 AM
  5. Source for good quality extension pole....
    By chrisexv6 in forum Pool Equipment & Operations
    Last Post: 05-17-2006, 12:02 PM
