Closed Thread
Results 1 to 10 of 36
Thread: Ok here we go
    kaybinster Guest
    Default
    I would suggest not to switch to bleach, but use it in combination with TriChlor. I have done this for about 4 years with great luck. As others mentioned TriChlor tends to drop the pH while bleach will raise it. Thus, I supply half the chlorine needs with bleach and half with TriChlor thus I never have any problems with the pH and never have to deal with things like pH up or pH down.
    Katy, TX
    Default
    Quote Originally Posted by kaybinster
    The problem with this is that you don't have any control over your CYA levels, which leads to:
    1. Reduced Cl effectiveness
    2. Accelerated plaster erosion (as discovered by a leading pool chemical supplier)
    Personally, when I was doing bleach, I controlled pH with muriatic acid. Simple and easy. No worries about how much CYA I was slamming into my pool with the tablets. I like adding one thing at a time, in quantities that I know about. That's what makes it easy to keep a pool in balance.
    Michael
    Lincolnton, NC
    Default
    Quote Originally Posted by mwsmith2
    Michael
    So you don't use chlorine pucks at all? You just use bleach for normal chlorination?
    Default
    Yes! Bleach is the only thing I ever use as a chlorine source. I have never had a puck in my pool since day one, not any chlorine granules either. My water is always great and I don't spend a fortune.
    Watermom
    IMherDad is offline ** No working email address ** IMherDad 0
    Memphis, TN.
    Smile Thanks for ...
    all the answers and help. So now I am purchasing one of Ben's new kits and waiting until we pull the winter cover off to start testing. I sure hope there are some great directions and instructions in the kit.
    Of course the wife is already looking for deals on bleach.
    cnk is offline ** No working email address ** cnk 0
    Default
    We recently changed over. The pool looks great now, but be prepared for some neon green water. My husband thought that I had ruined the pool.
    Katy, TX
    Default
    Quote Originally Posted by cnk
    This will only happen if you have a baquacil pool and you are converting it over to Chlorine.
    Michael
    Lincolnton, NC
    Default
    [QUOTE=Watermom]Yes! Bleach is the only thing I ever use as a chlorine source. I have never had a puck in my pool since day one, not any chlorine granules either. My water is always great and I don't spend a fortune.
    Watermom[/QUO
    Thanks Watermom.
    How do I add CYA if needed. Should I use trichlor pucks like cnix did until I get CYA right, then swith to straight bleach.
    Mc Donald, Tennessee, USA.
    Default
    I don't use pucks either. (Well, actually I used some last year after a drain/refill to add stabilizer.) It took only about 2 doz (from memory) over the course of 4-6 weeks and my stabilizer was up to 30 ppm starting from zero. The tri-chlor can really add CYA quickly.
    I switched to bleach and never looked back. I'll use maybe 30-40 gal of 6% bleach during a long Tennessee season, and about 3 gal of muriatic acid. That's all. The pool is sparkling clean and stays that way. In the heat of the summer I check Chlorine every 2-3 days; this time of year, about every 2-3 weeks.
    It takes maybe 5 minutes tops twice a week to get a rough chlorine check--close enough to monitor the level. Far simpler than trying to get rid of CYA. (I know--the previous owner's use of tri-chlor was what caused the drain/refill--CYA was in the 250+ range--looked like whole milk in the test vial)
    Chuck
    Katy, TX
    Default
    Quote Originally Posted by TfromNC
    I know this has already been answered, but yup, that's all I used. Easy too. Now I have a SWC, and life is even easier!
    Michael
Closed Thread
